JD and Kubota interchange
   / JD and Kubota interchange #1
tricel1
Dalton,Pa.
Yanmar YM336D
I have a Kubota 3130 with the Quick tach system and I saw in the paper a guy has a plow from a JD 4300 with quick tach.
Does the JD interchange with Kubota?
Thank you Ed
   / JD and Kubota interchange #2
I assume you speak of a front mount plow, and I strongly suspect that the two do not interchange with each other (unless you speak of the 3pt quick tach, and not one on the front end).
With 3pt quick tach, I think there is an SAE spec for a standard. If this is of what you speak, then there is a possibility that the two interchange with their respective quick tach systems (I-match for Deere). But this comment doesn't seem to fit with your original question.
Even with a standard SAE spec, a lot of the 3 pt attachments were not made to that spec, but in the future, they may be just so the lesser brands can compete with the big boys.
Bobcat has a system that many of the other mfg's are adapting, just because (IMO) Bobcat has such a large share of the market. I doubt neither Deere or Kubota feel they need to adapt to the other's specs. Know that I could be wrong.
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53472)
2021 John Deere...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2015 ISUZU NPR 16FT BOX TRUCK (A52576)
2015 ISUZU NPR...
