JD 997 Mower Advice Needed
   / JD 997 Mower Advice Needed #1
GreenTime
Bronze Member
North Dakota
JD 110TLB, JD 3720, JD Z997, Kubota L5740
I am going to look at a 2009 JD 997 zero turn mower this weekend (72" deck, 540 hours). I have really studied them and test drove one at a dealer this past fall so am quite familar with them. Any problem areas to really look at on a used machine? I am upgrading from a JD 430 60" deck diesel mower. Thanks!
   / JD 997 Mower Advice Needed #2
The objection I have heard is that the front axle does not pivot as the Kubota. The complaint was that causes issues on ditches, banks. This was coming from a gent that traded a Kubota on one. A test ride, if possible, may let you know if that is an issue for you.
   / JD 997 Mower Advice Needed #3
They are a 1700 pound indestructible tank. I really like mine (bought it new in 2013), but it is not real refined. I guess the main thing to look for is if it was maintained properly with hydraulic end engine oil changes. 540 is not many hours. They are good for several thousand.
   / JD 997 Mower Advice Needed #4
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53472)
2012 KINZE FLAT...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A51572)
2019 Ford F-550...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2021 FREIGHTLINER...
