JD 970 clutch
   / JD 970 clutch #1
mroldstyle
cataract wi
2003 New Holland tc 29d
Is there any adjustment on the clutch on a 970? seems to be slipping under load, and I dont have a manual. Whats involved in replacing? anyone have any ideas on cost?
Thanks:confused::confused:
   / JD 970 clutch #2
Clutch free travel should be less than 15mm and not more than 25mm. Adjustment is via a turnbuckle under the step plate. Remove the step plate to access the turnbuckle.
   / JD 970 clutch #3
Generally, there's several JD OEM manual's for the 870-970-1070 series on eBay. I bought the owner's manual and the Technical Repair manual on eBay. Very reasonably priced as I recall.
If you're only gonna buy one manual and you do most (or all) of your own maintainence and repairs - buy the Technical Repair Manual. Great book! Lot's of pictures and very well written.
AKfish
2022 Case IH Steiger 420HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2005 STERLING LT8500 SERIES MIXER TRUCK (A50854)
2005 STERLING...
2025 Swict 60in. Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
