955 isn't that "old".
John Deere 955
John Deere 955 tractor photo
1989 - 1998
Compact Utility tractor
Smaller: John Deere 855
Distributor: John Deere
Manufacturer: Yanmar
Factory: Japan
Original price (USD): $18,000 (1998)
John Deere 955 Engine:
Yanmar 1.4L 3-cyl diesel
Capacity:
Fuel: 6.6 gal [25.0 L]
Hydraulic system: 4.5 gal [17.0 L]
Front axle: 2.6 qts [2.5 L]
3-Point Hitch:
Rear Type: I
Rear lift (at 24"/610mm): 957 lbs [434 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540
Engine RPM: 540@3200
Mid PTO: independent
Mid RPM: 2100
Engine RPM: 2100@3200
Dimensions & Tires:
Wheelbase: 64 inches [162 cm]
Weight: 1,990 lbs [902 kg]
Front tire: 7.00-12
Rear tire: 11.2-16
John Deere 955 attachments:
mowing deck
front-end loader
backhoe
955 Serial Numbers:
1990: 10001
1991: 100001
1992: 100700
1993: 130000
1994: 165001
1995: 175130
1996: 190001
1997: 200001
1998: 300001
John Deere 955 Power:
Engine: 33 hp [24.6 kW]
Drawbar (claimed): 23 hp [17.2 kW]
PTO (claimed): 27 hp [20.1 kW]
Mechanical:
Chassis: 4x4 MFWD 4WD
Differential lock: standard
Steering: hydrostatic power
Brakes: differential hydraulic wet disc
Cab: Two-post Roll-Gard ROPS. Optional canopy and high ROPS with extra headroom. Optional weather enclosure.
Hydraulics:
Type: open center
Capacity: 4.5 gal [17.0 L]
Pressure: 2500 psi [172.4 bar]
Valves: 0 to 2
Total flow: 7.2 gpm [27.3 lpm]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 40
Battery:
Number: 1
Cold-cranking amps: 472
Volts: 12
