JD 955 Hydro pedals sticking in the winter?
   / JD 955 Hydro pedals sticking in the winter? #1
dallasfan458
Chester County, PA
John Deere 955
I have a John Deere 955 that's pedals seem to stick in forward and reverse if its below about 30, just have to tap or press the opposite pedal to stop it and wondering if anyone else has had a similar issue with hydro tractors. Local hydraulics guy said it could be that previous owner topped tank off with regular hydro oil when it is supposed to be JD hydro oil, Dad swears he changed it to that a few years ago. Any suggestions would be great.
   / JD 955 Hydro pedals sticking in the winter? #2
If you lay under the tractor and look up inside the opening in the tranny housing (engine off!!!!) while you work the pedal you will see a roller bearing riding up and down a "V" if this bearing/roller gets dry and quits rolling the pedals have a very hard time returning to center.
I have PDF's of the tractor tech, engine tech, and parts panual you're welcome to, shoot me your email if wanted
Joe
notch "V" location shown -
bearing location shown -
So you're saying part #25 from the second pic goes inside part #21 from the first? I have found the JD parts and schematic website that they use in the store so I should be able to get the part numbers. Is there a chance that the grease in the bearing could thicken in the cold temps? I'll take a look at it tomorrow to make sure it even has grease but that would be my first guess. Thanks.
John Deere 6215 (A50120)
John Deere 6215...
2010 Nissan Rogue SUV (A50324)
2010 Nissan Rogue...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A52748)
PENDING SELLER...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
John Deere 6115M (A50120)
John Deere 6115M...
78" Skidloader Log Grapple (A50774)
78" Skidloader Log...
