JD 955 FEL bucket problem
/ JD 955 FEL bucket problem #1
noose
Bronze Member
No City Slicker
None Yet
I've just purchased a used (and cheap) John Deere 955 and the bucket has some issues. The FEL raises and lowers perfectly. The farther the bucket is moved down toward dumping, the less likely it is to return. If about 1/2 way, a little jiggle on the control arm will bring it back up. All the way and it requires putting the bucket on the ground and backing up to get it to roll up again. Any suggestions on the first place to look? Given the bucket works in part of the range, I'd have to think this is more linkage or connectivity related rather than hydraulic or valve but who knows... I'm looking for some suggestions to try first before I take it to the dealership.
Thanks!
/ JD 955 FEL bucket problem #2
Perhaps a failed seal(s) in the bucket hydraulic Rams . On occasion the lining inside a hydraulic hose will flap loose . Making a rather effective one way valve inside the hose.
/ JD 955 FEL bucket problem #3
Sounds like one of the curl cylinders is fighting the other. Any chance the hose connections are backwards on one side? I'd pull the pins and see if one extends while the other retracts. You will have to figure out how to reconnect them, though.
Thanks guys. I'll take a look at it in the next couple of days and see if I can figure it out based on your advice.
