JD 950 starter issue
/ JD 950 starter issue #1
jonezy00
Smithville, TX
JD 950
I had the starter to my JD 950 rebuilt recently due to it sticking. Before I had it rebuilt, I got a puff of electrical smoke up from the fuel tank area when I turned on the ignition. I've have a new battery, rebuilt starter, and it still won't start (unless I use a long screw driver). There's power to the ignition, as the headlights and dash lights turn on/illuminate. I've also replaced the flasher relay, and some other relay ( Denso 12v 22a relay). When I try to start the tractor, I hear and feel a clicking in the new Denso relay. All of the fuses are good. Is there anything else between the starter and the ignition that I'm missing?
Thanks!:confused:
/ JD 950 starter issue #2
shoot me your email, I have a PDF of the tech manual with all the wiring in it
Joe
Joe,
I went through with a multimeter and found my issue. I need a new voltage regulator and a temperature sending unit. Thanks again!
Heavy-Duty Round Livestock Bale Feeder w/ Hay Saver (A66408)
Heavy-Duty Round...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2017 INTERNATIONAL LF687 DAYCAB (A65643)
2017 INTERNATIONAL...
1986 GMC C7000 Fertilizer/Spreader Truck, VIN # 1GDL7D1B8GV512761 (A65563)
1986 GMC C7000...
2015 A and A Melters A-110 Towable Hot Rubber Melter (A64553)
2015 A and A...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
