jd 950 Power Steering not working
/ jd 950 Power Steering not working #1
showlandjr
Mass
Ford and JD
Hi Guy's, thanks for all the great threads I have already read, now to see if I can get some information I could not find otherwise.
I have a late model 950 with power steering and FEL and when i got it recently the power steering cylinder fell out of the link, so instead of spending $100 I re-tapped with link with a helicoil and also re-threaded the end of the cylinder with a die. It now a good strong connection again but while working with it i undid the hoses connecting to the cylinder so they would be out of my way, on of them had come loose and I thought I might have broken it so i just undid them both so that it would stop squirting fluid.
So i put it all back together just as it says int he service manual and well, it just does not have any power to move the wheels while its stopped, which it could before. when I drive it turns easily but that would be true with out PS so it basically like I am running a tractor without PS. I tried unhooking both the cables and making sure that it was all squirting fluid and indeed it did. but when i once again hook it back up, no deal. With it unhooked I can push the cylinder in and it squirts out fluid so it's obviously getting fluid.
Any help would be much appreciated. I didn't have it apart much so i don't think that there any crud in the rest of the system. and I know it's full of fluid.
Thanks, Shelby
/ jd 950 Power Steering not working #2
I suspect that you have air in the valve, so you will need to operate
the steering full left and right numerous times to get it
working correctly. Otherwise, there is no special air bleed procedure.
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
(2) UNUSED 14X17.5 TIRES W/ 8 LUG RIMS (A64280)
(2) UNUSED 14X17.5...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
2019 Nissan Maxima Sedan (A61574)
2019 Nissan Maxima...
2022 EZ-GO ELITE...
**SALVAGE ROW STARTS HERE** (A64280)
**SALVAGE ROW...
