Oil & Fuel JD 855 Oil Leak
   / JD 855 Oil Leak #1
DudeJohnDeere
Walworth, NY
1940 Allis Chalmers B, 1992 John Deere 445, 1998 John Deere 855, 2001 John Deere SST18, 2007 John Deere Gator TX and many others at the farm yard
I have a 1998 John Deere 855. It is leaking hydraulic oil profusely from somewhere on the transmission. I am a big guy and I currently have the backhoe on my tractor which is why I am making this post. I would prefer to not have to take the backhoe off until I'm done using it or until I know where the oil is coming from. Please let me know if you have the same problem. The leak started back in August and is getting progressively worse. It is to the point where I have to add about 1 gallon of oil every two weeks.
   / JD 855 Oil Leak #2
Can you get us a bit closer to where the oil leak is "on" the transmission? Pics of it would help.
   / JD 855 Oil Leak #3
Yeah, we sure can't get under it from here and look for you. My first guess would be the filter. Perhaps it's loose or you high centered and split it. Who changed the filter last time? :cool:
   / JD 855 Oil Leak
The tractor is not currently at my house. The oil seems to be coming from the center of the tractor almost directly under the seat.
   / JD 855 Oil Leak #5
Will look forward to when you can get some pics of where that is coming from..
The oil filter change answer to Tinhack's question will help.. along with your pics.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
2019 CASCADE DM0B1300 HYD BALE CLAMP (A51247)
2019 CASCADE...
CAT 973 (A47384)
CAT 973 (A47384)
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
