Mowing JD 855 Mid PTO drive problem
   / JD 855 Mid PTO drive problem #1
Garth50
Brisbane, QLD, AUS
JD 855
Hi. I have a JD855 with the 72 inch mower deck. It has worked perfectly for years, but recently started losing PTO drive while mowing. It is not the drive disconnecting as the magnet is still engaged. When it happens I can hear the load come off the motor and the deck sounds like it is free wheeling, until it eventually stops. The brake does not come on until I disengage the PTO drive. Disengage and engage the PTO drive and it will work until the next drop out. I think it is load dependent although if I leave it running with no load it will free wheel after a minute or so. I suspect a problem with the PTO clutch piston or clutch because the PTO brake and Delay Relief valve are working normally - implying no problems with hydraulic pressure, correct? Any thoughts before I start pulling the back end apart? Thanks in advance, it is mid summer here and the grass is growing fast.
   / JD 855 Mid PTO drive problem #2
:welcome: to TBN
Do you have the service tech manual for some assistance?
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A52141)
2015 INTERNATIONAL...
2019 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2019 JLG ECOLIFT...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51243)
(NEW) 2025 DOWN 2...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51243)
2006 FORD F-450...
1996 FREIGHTLINER FL70 S/A GRAIN TRUCK (A51243)
1996 FREIGHTLINER...
John Deere 5203 Tractor (RIDE AND DRIVE) (A50774)
John Deere 5203...
