JD 855 Hydraulic problem
   / JD 855 Hydraulic problem #1
srhorsefarm
Eastern Pa
JD 855
I have a Jd 855 that has a real bad habit of squealing under the seat when the cylinders on my loader are fully stroked in or out and I also lost a lot of
lifting ability with the 3PT. I just purchased a service manual but would like to get as much input as possible to avoid any unnecessary labor. Any info
would be greatly appreciated. (PS I had a most of hydraulic system apart
under the seat looking for something obvious including the rock shaft thought the screen might be clogged.
Thanks, Mike
   / JD 855 Hydraulic problem #2
I would guess that the pressure relief valve is opening too easily. You should take it out (probably a couple washers, a spring and a rounded cup) and see if there is a chunk of gunk keeping it from closing all the way.
I assume that you have already changed the filter in teh system and cleaned any screens, checked fluid levels and have no water in the fluid.
jb
   / JD 855 Hydraulic problem #3
Definitely sounds like a relief valve problem-I suggest you get a gauge and take a measurement of the system pressure. You can get a gauge at TSC or online for under $20.
Komatsu 330 Excavator (A51573)
Komatsu 330...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
MALONE 3000TP LOT NUMBER 229 (A53084)
MALONE 3000TP LOT...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
