JD 850 Question
   / JD 850 Question #1
bodywash
My JD 1984 850 has approximately 900 hrs on it. It starts easy, runs great, seems to have lots of power etc. However, it has a fairly loud knock which is most noticeable at idle. It also smokes a bit -- appears to be white smoke with MAYBE a touch of blue. Every few seconds it appears to puff out more smoke than usual, and I think it also makes a very light bump sound when it puffs the smoke. There is no water in the oil, no gas bubbles in the radiator. It has new injectors. Any ideas on what I should look for? Thanks
Scott
   / JD 850 Question #2
Make sure your delivery valves are tight. those are the "fittings" that stick out of the injection pump.
   / JD 850 Question #3
Your JD 850 has a Yanmar engine which is known for making a fairly loud knock especially when cold, "Yanmar Hammer". I believe that the condition you are describing is normal for this engine. I would try a little Power Service in the fuel to see if it helps the smoking problem.
Ken /forums/images/graemlins/smile.gif
   / JD 850 Question #4
If it is only at slow idle, I am not sure I would worry too much. I have an '84 JD 950 with 2100+ hours. It is also pretty loud at slow idle but smooths out as I increase the rpms. Mine doesn't smoke though except when I first start it up or put it under heavy load.
2016 Ram 4500 Chassis Wheeled Coach Ambulance (A48081)
2016 Ram 4500...
PALLET OF MISC TILE FLOORING (A50460)
PALLET OF MISC...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A50458)
2023 JOHN DEERE...
2007 Chrysler Aspen (MPV), VIN # 1A8HW582X7F516547 (A48836)
2007 Chrysler...
UNUSED RAYTREE QUICK ATTACH SOIL CONDITIONER (A50460)
UNUSED RAYTREE...
New/Unused 7ft 18 Drawer Work Bench (A48837)
New/Unused 7ft 18...
