I have a 1968 JD 820. Was bushhogging on a slight grade and pushed in the clutch pedal but the tractor continued to move forward in gear and the clutch did not disengage. Drove tractor to the barn and worked the pedal a few times but the problem remains. The clutch had worked fine and showed no indication of slipping, etc. This clutch was replaced about 2 years ago when I had the entire tractor overhauled. Any ideas on what the problem is? Looking for suggestions before I split the tractor apart.
