Backhoe JD 790 with JD#7 backhoe question
   / JD 790 with JD#7 backhoe question #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I recently bought a 790 w/ 7 backhoe and the backhoe owner's manual only gives info for attaching/removing to the 55 (755) and 70 (770) series of tractors. No mention of the 90 series 790.
I know mine doesn't look like the 755 so I should probably use the info for the 770-type trctors? Does that sound right?
I dont want to buy a new owner's manual for just a small amount of info.
Thanks...
   / JD 790 with JD#7 backhoe question #2
The 770 is the predecessor of the 790. Other then the engine and tires, it's identical, so yes...use the 770 instructions.
   / JD 790 with JD#7 backhoe question #3
What Roy said, plus if you do run into any snags let me know. I have your setup with all the manuals. Which loader do you have?
Rob S --
The loader is a 419. Whole rig has 100 ours on it and is a 2003.
I have bigger loader tractor so this is just for around the house.
But I do wonder how much the loader will lift. Maybe 500 lbs?
I do have all the manuals but the backoe makes no mention of a 790 only the770. Thank you.
Roy Jackson--thanks for your reply.
Assortment of Light Poles (A50121)
Assortment of...
Toro Reelmaster 3100D Reel Mower (A50121)
Toro Reelmaster...
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
2018 Bobcat T590 (A50120)
2018 Bobcat T590...
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
