sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,689
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a JD 790 that I am changing the trans oil and filter and cleaning the strainer. To clean the strainer you remove three bolts on it's cover, remove the strainer, clean and re-install.
The question regarding reinstalling is---do I just slide the strainer back into the transmission case and then put the cap back on OR do I first push the end of the strainer INTO the cap and then slide the assembly back into the trans case? The end of the strainer will fit into the cap.
It's a small point but sometimes these things matter. If anyone has any idea or has cleaned their strainer, please let me know. Probably the same as other Yanmar-built models.
