Buying Advice JD 790 or NH TC30 Which is better?
   / JD 790 or NH TC30 Which is better? #11
I've owned both a 790 and a TC30. TC30 would be my pick for the following reasons: 3 ranges instead of 2, shifter on steering column instead of on the floor, NH is built heavier - heavier axle castings, wider stance and (perceived) lower center of gravity on TC30 makes it feel more stable, no plastic on TC30, Controls setup is preferable overall (to me, anyway).
Both should be dead reliable for thousands of hours. Either way you go, I don't think you can pick a bad tractor.
Thank you for all your replies. Found a TC 30 close. Going to look at it.
   / JD 790 or NH TC30 Which is better? #13
Glad I didn't see this thread a couple of weeks ago!!!
I had been looking at a 790 and just couldn't pull the trigger.....Ran across a TC 30 in basically as good or better shape as the 790 i was agonizing over...the difference was the TC was 2k cheaper and came with 15 pieces of equipment. I have been VERY pleased with the TC 30. I've had it to the limit several times!
If We bring home the TC 30 It will be the first non green tractor ever.
Green and yellow make blue. right?
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
John Deer 3 Point Quick Attach (A59076)
John Deer 3 Point...
2014 BMW X1 AWD SUV (A56859)
2014 BMW X1 AWD...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2010 KENWORTH T660 TANDEM AXLE MID ROOF SLEEPER (A58017)
2010 KENWORTH T660...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
