JD 790 hydraulic extension
   / JD 790 hydraulic extension #1
RussHesch
West Branch, MI
JD 790
My JD 790 tractor [LV0790G296509] has a factory installed SCV for the FEL. I want to use a 3-point log splitter attachment. Where do I connect the hydraulic lines with quick disconnects to the hydraulic system on this tractor?
   / JD 790 hydraulic extension #2
If it were my tractor I'd plug the log splitter into a "pair of breakaways" for the SCV and bunge cord the lever to activate the log splitter valve. This is if the log splitter control valve is an open center valve.
   / JD 790 hydraulic extension #3
John deere sella a "power Beyond Kit". Easy to install. It will give you quick disconnects to the rear of your tractor. Your log splitter will still have to have an open center valve to heep fluid moving.
Does the "regen" circuit need to be operative or locked out?
   / JD 790 hydraulic extension #5
You normally only see regen on loader valves. It is normally used in the loader curl circuit fast dump mode
What regen are you talking about?
   / JD 790 hydraulic extension #6
Tx Jim said: If it were my tractor I'd plug the log splitter into a "pair of breakaways" for the SCV and bunge cord the lever to activate the log splitter valve. This is if the log splitter control valve is an open center valve.
And it is the SCV regen I'm talking about.
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
2018 FORD TRANSIT T150 CARGO VAN (A54313)
2018 FORD TRANSIT...
1969 Jeep 4x4 (A54865)
UNUSED LANDHONOR FW-13-15000G HYD WINCH (A54757)
UNUSED LANDHONOR...
2019 Chevrolet Express 2500 Cargo Van (A53422)
2019 Chevrolet...
2016 VOLVO VNL SLEEPER (A54313)
2016 VOLVO VNL...
