JD 790 hydraulic extension
   / JD 790 hydraulic extension #1
RussHesch
West Branch, MI
JD 790
My JD 790 tractor [LV0790G296509] has a factory installed SCV for the FEL. I want to use a 3-point log splitter attachment. Where do I connect the hydraulic lines with quick disconnects to the hydraulic system on this tractor?
   / JD 790 hydraulic extension #2
If it were my tractor I'd plug the log splitter into a "pair of breakaways" for the SCV and bunge cord the lever to activate the log splitter valve. This is if the log splitter control valve is an open center valve.
   / JD 790 hydraulic extension #3
John deere sella a "power Beyond Kit". Easy to install. It will give you quick disconnects to the rear of your tractor. Your log splitter will still have to have an open center valve to heep fluid moving.
Does the "regen" circuit need to be operative or locked out?
   / JD 790 hydraulic extension #5
You normally only see regen on loader valves. It is normally used in the loader curl circuit fast dump mode
What regen are you talking about?
   / JD 790 hydraulic extension #6
Tx Jim said: If it were my tractor I'd plug the log splitter into a "pair of breakaways" for the SCV and bunge cord the lever to activate the log splitter valve. This is if the log splitter control valve is an open center valve.
And it is the SCV regen I'm talking about.
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A55787)
2025 GIYI SGB20...
RoGator RG1100C (A55302)
RoGator RG1100C...
2012 JCB 930 ROUGH TERRAIN FORKLIFT (A52705)
2012 JCB 930 ROUGH...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
UNUSED 3.5X2X2M GREEHOUSE (A54757)
UNUSED 3.5X2X2M...
Dump bed (A51692)
Dump bed (A51692)
