JD 770
   / JD 770
em14 said:
Don't you need to have a middle PTO to use the MMM and does this tractor have that. I think you should vist the local John Deere Dealer and talk to them about your thoughts. And if if the tractor is 4 wheel drive I don't think it can use a MMM can it?
Leo
Yes, the mid PTO is already installed. I have seen other 4wd tractors w/MMM, but will check and see where we end up. The only pitfall will probably be the mounting linkages.
   / JD 770 #12
Hi,
I don't wqnt to hijack this thread, but was model of Optima battery did you get?
Thanks.
Mike S.
   / JD 770
Michigan_Mike said:
Hi,
Thanks.
Mike S.
We used a blue top battery. It was sitting in the corner of the shop. Now, will have to buy a new one for the boat this spring :(
Hercules 25 Gallon Sprayer (A53316)
Hercules 25 Gallon...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
Auger Skid Steer Attachment (A55787)
Auger Skid Steer...
