jd 770 pto
   / jd 770 pto #1
jerry45
does anyone know if the 770 2wd has a live pto. does it keep running when the clutch is pressed. thanks
   / jd 770 pto #2
Unless it has a dual stage clutch, the PTO is disengaged when the clutch is depressed.
Since this is a two wheel drive machine, it probably does not have a dual stage clutch.
My first tractor, a Deere 670, had a single stage clutch. It's pretty easy to adapt your mowing to this. You may have to back up to hit small areas you missed when clutching, but that isn't too much to deal with.
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
Daewoo G25E-3 Forklift (A50860)
Daewoo G25E-3...
Apache 8800E Gasoline Generator (A50860)
Apache 8800E...
2015 Ford F-150 4x4 Pickup Truck (A48081)
2015 Ford F-150...
