JD 755 rear locker clicking
   / JD 755 rear locker clicking #1
v8only
Mb
1988 John Deere 755
Hey there I have started to notice that when i press the lever for the rear locker and press the fwd/reverse pedals the locker starts to click and i can feel the lever engage/disengage on my heel if that makes sense. It almost feels as that with my heal down the lever rides up and down as the diff rotates?
What can this be?
Thanks.
   / JD 755 rear locker clicking #2
Locking mechanism is not fully engaging. Could either be a linkage travel adjustment issue or the teeth on the locking collar/diff are shot.
Are there other symptoms that would indicate locking collar/diff gears that are shot?
   / JD 755 rear locker clicking #4
You could drain the fluid pull the strainer screen. Then look up into the hole with a flashlight. If can get the right angle, you should be able to see the locking mechanism and assess the condition of the teeth.
have you check the linkage for wear and proper adjustment.
2001 HEIL PNEUMATIC CEMENT TRAILER (A51222)
2001 HEIL...
Tree Boom (A50322)
Tree Boom (A50322)
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2016 Ford F-450...
