JD 755 no start problem solved.
   / JD 755 no start problem solved. #1
65specialk
Kubota L 7800
Thanks guys for your help. Got it going today. I checked all the circuits on the fuel solenoid and all checked out ok. I removed the pin from the linkage and turned over the engine while moving the lever. It started right up. The only problem was the linkage was out of adjustment. I tightened it and backed it off two turns to allow some free play. Very touchy adjustment . Runs like a champ. Dealer told me it need a fuel pump rebuild for around $1500. It is starting out to be a good year!!! Dave
   / JD 755 no start problem solved. #2
Gives you a good feeling to have cheated the dealer out of $1500 I would think.
Spend the savings wisely:thumbsup:
   / JD 755 no start problem solved. #3
IIRC, wasn't the dealer first telling you that the TDC module needed to be replaced? Then he moved on to say that the fuel pump need to be rebuilt (at $1500, I'm assuming they were wanting to rebuild the injection pump)? If it were me... I'd find a different dealer. Sounds to me like their service dept. couldn't find their *** with both hands.
   / JD 755 no start problem solved. #4
By starting this new thread, you left the old thread in the Deere Owning and Operating forum hanging without the solution to your problem. Good to keep a thread going until closure. ;)
Glad you are up and running.
http://www.tractorbynet.com/forums/john-deere-owning-operating/229027-jd-755-not-starting.html
   / JD 755 no start problem solved. #5
Glad you got it going Dave and saved money too
2013 JLG 8042 TELEHANDLER (A50854)
2013 JLG 8042...
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
2005 STERLING LT8500 SERIES MIXER TRUCK (A50854)
2005 STERLING...
2014 Ag Spray Schaben Sidedresser (A51039)
2014 Ag Spray...
2020 John Deere 35G Mini Excavator (A49461)
2020 John Deere...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
