JD 755 no start problem solved.
/ JD 755 no start problem solved. #1
65specialk
Kubota L 7800
Thanks guys for your help. Got it going today. I checked all the circuits on the fuel solenoid and all checked out ok. I removed the pin from the linkage and turned over the engine while moving the lever. It started right up. The only problem was the linkage was out of adjustment. I tightened it and backed it off two turns to allow some free play. Very touchy adjustment . Runs like a champ. Dealer told me it need a fuel pump rebuild for around $1500. It is starting out to be a good year!!! Dave
/ JD 755 no start problem solved. #2
Gives you a good feeling to have cheated the dealer out of $1500 I would think.
Spend the savings wisely:thumbsup:
/ JD 755 no start problem solved. #3
IIRC, wasn't the dealer first telling you that the TDC module needed to be replaced? Then he moved on to say that the fuel pump need to be rebuilt (at $1500, I'm assuming they were wanting to rebuild the injection pump)? If it were me... I'd find a different dealer. Sounds to me like their service dept. couldn't find their *** with both hands.
/ JD 755 no start problem solved. #4
By starting this new thread, you left the old thread in the Deere Owning and Operating forum hanging without the solution to your problem. Good to keep a thread going until closure. ;)
Glad you are up and running.
http://www.tractorbynet.com/forums/john-deere-owning-operating/229027-jd-755-not-starting.html
/ JD 755 no start problem solved. #5
Glad you got it going Dave and saved money too
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2001 FORD SUPER DUTY F350 4x4 UTILITY TRUCK (A59912)
2001 FORD SUPER...
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
UNUSED WOLVERINE HYD AUGER (A64281)
UNUSED WOLVERINE...
UNUSED WOLVERINE HYD TRENCHER (A64281)
UNUSED WOLVERINE...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
