JD 755 hydraulic top link
   / JD 755 hydraulic top link #1
honda432
I would like to add a hydraulic top link to my JD 755, the tractor has the joystick for the front loader but I don't have a loader or plan to get one. My plan was to put a T in two of the the lines and run the hoses to the back of the tractor with quick connects on them to use as aux lines for the top link or lift arm on my sickle mower. That way I can still use the factory lines for a future front mount snow blower, with the top link disconnected of course. Am I wrong in thinking this would work or is it more complicated than that. I believe it will work since it looks like that is how my mower lift cylinder is hooked up. If it would work does anybody know what quick connect to use for the rear. I would like to get them to match the factory ones but not sure on the type the factory ones are.
   / JD 755 hydraulic top link #2
Welcome to TBN:D
It will work fine, provided only one thing is powered at a time, the other QDs on the other side of the Tee must be empty.
What size and style T would I need if I wanted to split the line directly off the joystick? All that is Greek to me. Thanks.
   / JD 755 hydraulic top link #4
You need to identify what type of fitting and the size you have where you want to place the Tee. Do NOT use cheaper plumbing fittings. I do not know.
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
17801 (A51694)
17801 (A51694)
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A50323)
2008 Ford E-350...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
