JD 755 hydraulic top link
   / JD 755 hydraulic top link #1
honda432
I would like to add a hydraulic top link to my JD 755, the tractor has the joystick for the front loader but I don't have a loader or plan to get one. My plan was to put a T in two of the the lines and run the hoses to the back of the tractor with quick connects on them to use as aux lines for the top link or lift arm on my sickle mower. That way I can still use the factory lines for a future front mount snow blower, with the top link disconnected of course. Am I wrong in thinking this would work or is it more complicated than that. I believe it will work since it looks like that is how my mower lift cylinder is hooked up. If it would work does anybody know what quick connect to use for the rear. I would like to get them to match the factory ones but not sure on the type the factory ones are.
   / JD 755 hydraulic top link #2
Welcome to TBN:D
It will work fine, provided only one thing is powered at a time, the other QDs on the other side of the Tee must be empty.
What size and style T would I need if I wanted to split the line directly off the joystick? All that is Greek to me. Thanks.
   / JD 755 hydraulic top link #4
You need to identify what type of fitting and the size you have where you want to place the Tee. Do NOT use cheaper plumbing fittings. I do not know.
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
Satoh S-650G Tractor (AS IS) (A50774)
Satoh S-650G...
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
2013 Mitsubishi Fuso FEC92S 16ft. Reefer Box Truck (A50323)
2013 Mitsubishi...
