JD 755 hyd cylinder repair
   / JD 755 hyd cylinder repair #1
bmich
Have a JD 755 tractor that the mid mount mower lift cylinder is leaking. Part # LVA 23449. No rebuild kit from JD is available and the end caps on the cylinder are welded on as an assembly. Is there any way of taking this unit apart to re seal it or am I forced to replace it for the rape me price of $550.00?
   / JD 755 hyd cylinder repair #2
A good hydraulic shop can cut the end off, repack, and reweld it, be sure to take it and show them for a quote, may or may not be worth repairing it.
   / JD 755 hyd cylinder repair #3
It is also possible said repair shop can order a cylinder in the same configuration for less money than Deere - green paint optional.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
80in HD Tooth Bucket with Side Cutters (A53472)
80in HD Tooth...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2014 International Sweeper Truck (A52377)
2014 International...
