Oil & Fuel JD 755 fuel and oil mixing
   / JD 755 fuel and oil mixing #1
Wolfman37
Wisconsin
JD 755
Son was driving tractor. Somehow, the fuel line became disconnected???
He re-connected it. Fuel ends up in the oil.
Drained oil/fuel mixture. New filter, new oil.
Tried to bleed the system, no bubbles. Loosened injectors - no bubbles. No fuel into the sediment bowl.
Fuel still going into oil.
What is wrong, and how do I fix it?
Thanks for any suggestions.
   / JD 755 fuel and oil mixing #2
Those the most details you can offer? What fuel line? How does it get reconnected for the fuel to end up in the oil? And which oil....the hyd. oil or the engine oil?
Is the line reconnected to the right place now?
Is the son a mechanic? Not that it really makes any difference.
Need more info. ;)
   / JD 755 fuel and oil mixing #3
Does this tractor have a low pressure mechanical fuel pump that primes the high pressure injector pump? If so, it could be a hole in the diaphram of that pump. The fuel could leak through the diaphram into the oil where the mechanical drive arm of the pump enters the block. If the diaphram is shot, it would also explain why the sediment bowl isn't filling. If the sediment bowl doesn't fill, the tractor is not going to start.
Regarding your son reconnecting the fuel line, I don't know.
I have an 855 and I believe some models use a mechanical transfer pump and some use an electrical one.
Go to the John Deere parts web-site and look at the exploded view diagram
19200 (A50324)
19200 (A50324)
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
BUYER'S PREMIUM INFO LOT IDENTIFIER 2 (A53084)
BUYER'S PREMIUM...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
2002 Freightliner FL70 Elgin Street Sweeper Truck (A51692)
2002 Freightliner...
