JD 755 1993? Enough?
/ JD 755 1993? Enough? #11
sagaponack
I for got to mention that my 755 had turf tires on it. It did fine just leave the loader on for field work. the extra weight helps traction.
What kind of grass seeder are you looking at, any prices?
DDT
I am looking for a grass seeder that can handle wildflower seeds. Will be using it pretty exclusively for wildflowers.
Looking to spend as little as possible. But know I may need to get to $2k.
/ JD 755 1993? Enough? #13
1st timer here. Live in iowa. Couldnt resist giving you my advice. I have a 95 755. Take my advice and equip it in this way. It helps out bunches! 1st thing you need to do is fill your rear tires with fluid. If you have a full load of something, especially wet in your bucket, your really light in the back end. FILL EM! 2nd, take them turf tires off your fronts. Put the industrial tires(not ag ones) on your fronts. It helps out SOOOOOOO much! Doesnt really tear up the turf either. Attachemnts I got are 50" Land Pride rotor tiller, 10"auger on a Land Pride post hole digger, 5' rear articulating blade, and a 5 foot landscape rake. Would like to have a backhoe attachement but alas, it would sit to much betwen uses.
Just found this forum from an atv website. This is a good thing! Hi all.
2017 BX2680 Sub Compact Utility Tractor (A61307)
2017 BX2680 Sub...
KBH Tender Trailer (A61307)
KBH Tender Trailer...
2025 Unused SDLGC80 Electric Golf Cart (A60352)
2025 Unused...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pick-Up Truck (A60352)
2023 GMC 1500...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
2018 Ford F-350 (A55973)
2018 Ford F-350...
