JD 755 1993? Enough?
   / JD 755 1993? Enough? #1
sagaponack
Bronze Member
Sagaponack, NY
JD 755 1993
Had been looking for a 4300, 4310. Found a great deal locally on a '93 JD 755 about 20hp with all the implements.
I am concerned that 20hp is not enough power. I need to be tilling two fields. One was cut feed corn,the other cut wild flowers. Total acreage under 2. The JD has hydo, 4wd, and turf tires and FEL.
If it is just going to take me longer than with a 30hp tractor that is fine. But if 20hp can't till or use a brush hog well, than I am in trouble.
The fields are clayey, flat and in Long Island, N.Y. and I need to get to work fast. I will till and then seed sundlowers, feedcorn, and wild flowers this spring.
   / JD 755 1993? Enough? #2
A 20hp tractor can till and brush hog just fine if it has the right sized implements, and of course, that means smaller than a bigger tractor would use, and therefore, more time to do the jobs. I've sure done a lot of brush hogging with a 48" brush hog and tilling with a 40" tiller on a Kubota B7100 (16 engine and 13 PTO hp).
that is exactly the size tiller the 755 is coming with a 40". And it has 17hp to the pto.
Thanks for the response.
   / JD 755 1993? Enough? #4
sagaponack
A 755 was the first tractor I had. It handled a landpride 15-50" tiller fine, it knew it was there but did handle it. I had a 5' bush hog and it was more than she wanted in taller stuff, a 4' model would be more to right. The 755 & 855 were very good tractors for me.
DDT
Thanks. My 4310 package was going to cost $30k with tax and shipping. I am doing the 755 with hog, fel, tiller, rake, finishing mower, ph digger just over $10K. I just need to buy the seeder and planter and hopefully will be ok. Will be serviced by the jd dealer too. Glad you had a good experience. Was worried about the hp size.
   / JD 755 1993? Enough? #6
That's one heck of a deal!!!
For working 2 acres, the 4300 would have probably been too much tractor. You're buying a machine (and implements) that should fit your needs perfectly!
   / JD 755 1993? Enough? #7
Sounds like a pretty good deal to me. My only concern might be with the turf tires. But ofcourse I don't own a fwd tractor with turf tires. May work just fine. I'm sure that someone on here will tell you though. /w3tcompact/icons/smile.gif
Bill
I am doing a lot work which requires traversing a manicured lawn. That's why I am using turf tires. Will it hurt my ability to use the tiller effectively?
Rob
   / JD 755 1993? Enough? #9
you will loose some traction with the turf tires, but overall should be fine. The 755 is a good size for 2 acres. I don't think you will regret the purchase.
   / JD 755 1993? Enough? #10
the 755 should do u fine and with all the implements u are getting sounds like a real good deal. as for turfs, u will lose some traction, but if u need to be kind to a lawn they are your best bet.if u find u don't like them u could go to bar/turfs or r4's notas likd to your lawn but not bad if u stay out of 4wd while on t. and turn slow.
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
STORAGE FEES (A51219)
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
Target Econline 2 Concrete Saw (A49461)
Target Econline 2...
John Deere LX5 3 pt Rotary Mower (A50515)
John Deere LX5 3...
2010 VOLVO ECR145CL EXCAVATOR (A50854)
2010 VOLVO...
