JD 750 needs new wheels
   / JD 750 needs new wheels #1
Pocketfarmer
long Island ,New York
John Deere 750
Hi I own a John Deere 750. I am the second one to own it. It still has its original turf tires and they are coming to the end . Do any of you have some insights into what R4 tires would fit? I want a little more traction. thanks
   / JD 750 needs new wheels #2
:welcome:
This question should go in the Deere forums, not in the new member intro. :)
But..........
Probably will need to get rims as well as tires if changing to R-4's.
Check with your Deere dealer to see what is in the books.
Once you have the size of the rims (stamped on the rim), then I'd suggest going on-line to see what is available.
   / JD 750 needs new wheels #4
Welcome to TBN Faux. If you change your mind and want to keep your turf tires......I have a set of turf FRONT tires and wheels I may sell. They are from my 790 (same size I think) and the guy before me bought them for his lawn needs. I never use 'em. They are like new. I'm in MN.
Also....as long as were passing out advice (grin)....fill out your profile so people know what tractor you have and where your from. Again...welcome!
   / JD 750 needs new wheels #5
Turf wheels and tire sizes are typically a breed of their own. It is usually very difficult and in many cases not possible to get a r4 ind or r1 ag tire for a turf wheel. In the cases that you can it can be difficult to maintain a correct rolling radius from front to rear. Your best option is to take your tire size to a tire shop and have them check for you. Otherwise buying new wheels is your next option. This is typically just a problem for the rear wheels/tires fronts are most often available in any style.
2001 MACK CH613 DAY CAB (A54313)
2001 MACK CH613...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
1718 (A54756)
1718 (A54756)
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
