JD 750 hydraulic whine???
   / JD 750 hydraulic whine??? #1
dane6895
wapwallopen, PA
John Deere 750
I have aJD 750 with hydraulic controls mounted on th tractor. I had a four angle plow on it thatworked fine. I bought a model 67 loader off a working machine. After installing it, I have a nasty whine when lifting the loader. I tried swapping the lines, and it follows the line to the other control. I serviced and cleaned the filter, etc. It wont pick up a load either. I found a worn cup on the relief valve that would explain no lift. But why the whine? Do I need to flush the lines on the loader? Or would a bad cylinder cause this? One does have a small leak. The three point hydraulic works with no noise. I changes out the quick disconnects on it as well. Im at aloss. Can someone give me some knowledge? :confused:
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2006 International 7400 Dump Truck (A47477)
2006 International...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
