Planters JD 71 Flex Planter Gauage Shoe?
   / JD 71 Flex Planter Gauage Shoe? #1
bjr
Eastern WA
Jinma JM354
JD Parts show a gauge shoe that can be mounted just ahead of the disc openers, has anyone ever used these and in what kind of soil conditions? I'm having trouble trying to keep the openers from going to deep in soft soil (rototilled garden and maybe uneven surface conditions) and was wondering if mounting a shoe plate to smooth out the surface ahead of the openers would be of benefit. I'm using a four row setup. bjr
   / JD 71 Flex Planter Gauage Shoe? #2
Hey bjr,
Check out the depth bands the mount to the side of your disks, I got a set of them to put on ours, looks like they will do what you want.
   / JD 71 Flex Planter Gauage Shoe? #3
I have the front compaction wheel on my JD 71 and cole planter. Makes all the difference in the world for depth control in my well worked up soft soil. Another option is the depth bands.
   / JD 71 Flex Planter Gauage Shoe? #4
You guys have me thinking. What about spacing the row unit so it runs in the center of the tractor tire track? Assuming you had the garden soil really fluffed up by roto tilling, it might work about right. We need to run an experiment.
I've investigated a little at the JD Dealer and what parts that are available prohibitively expensive. I see pictures of some of these planters with standard looking car tire guage wheels and axle mounted right to the tool bar. Has anyone else use that setup? I was thinking of using the laminated tire/wheel for a field mower setup from Agri-Supply and mount it right to the tool bar. Do Tool bar guage wheels work or is there problems? I don't know how to post links like you guy do? bjr
400 X 8 LAMINATED TIRE & WHITE WHEEL 4 B - Agri Supply
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2014 Ford F-150 Pickup Truck (A50323)
2014 Ford F-150...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2004 Chevy 1500 Pick Up (A50515)
2004 Chevy 1500...
