JD 70a bucket and boom hydraulic cylinder specs
   / JD 70a bucket and boom hydraulic cylinder specs #1
jgwhite
Arnprior, Ontario
John Deere 955
Hello all,
Still waiting on receiving my manual but in the meantime is there somebody who has the specs for the FEL 70bucket AW28948 and boom AW28947 cylinders.
AW28948:
Max. Continuous Pressure ? PSI
Bore Diameter ? in.
Stroke Length ? in.
Retracted Length (pin to pin) ? in.
Rod Diameter ? in.
Port Size ? ORBF
Pinhole Diameter ? in.
Base Pin Eye Width ? in.
Rod Pin Eye Width ? in.
Force at Maximum Pressure ? lb
AW28947
Bore Diameter ? in.
Stroke Length ? in.
Rod Diameter ? in.
Port Size ? ORBF
Thank you
Cheers,
John
   / JD 70a bucket and boom hydraulic cylinder specs #2
Here's a start Ports are SAE 4
   / JD 70a bucket and boom hydraulic cylinder specs #3
I guess you're still waiting on your tape measure to arrive as well. :laughing:
Boom:
Bore - 1.5"
Stroke - 17.25"
Retracted - 24.75"
Pin - 0.75"
Rod - 1.125"
Bucket:
Bore - 1.75"
Stroke - 13.75"
Retracted - 28"
Pin - 0.75"
Rod - 1.125"
   / JD 70a bucket and boom hydraulic cylinder specs #4
Maybe he got a deal on a loader with missing cylinders and is looking for non JD replacements? He wanted a LOT of info!
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
2021 Bell B30E Off Road Dump Truck (A53117)
2021 Bell B30E Off...
2008 Ford F-250 (A53473)
2008 Ford F-250...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
FUEL PUMP W/NOZZLE (A53843)
FUEL PUMP W/NOZZLE...
2015 Kia Sedona Van (A51694)
2015 Kia Sedona...
