JD 70a bucket and boom hydraulic cylinder specs
   / JD 70a bucket and boom hydraulic cylinder specs #1
jgwhite
Arnprior, Ontario
John Deere 955
Hello all,
Still waiting on receiving my manual but in the meantime is there somebody who has the specs for the FEL 70bucket AW28948 and boom AW28947 cylinders.
AW28948:
Max. Continuous Pressure ? PSI
Bore Diameter ? in.
Stroke Length ? in.
Retracted Length (pin to pin) ? in.
Rod Diameter ? in.
Port Size ? ORBF
Pinhole Diameter ? in.
Base Pin Eye Width ? in.
Rod Pin Eye Width ? in.
Force at Maximum Pressure ? lb
AW28947
Bore Diameter ? in.
Stroke Length ? in.
Rod Diameter ? in.
Port Size ? ORBF
Thank you
Cheers,
John
   / JD 70a bucket and boom hydraulic cylinder specs #2
Here's a start Ports are SAE 4
   / JD 70a bucket and boom hydraulic cylinder specs #3
I guess you're still waiting on your tape measure to arrive as well. :laughing:
Boom:
Bore - 1.5"
Stroke - 17.25"
Retracted - 24.75"
Pin - 0.75"
Rod - 1.125"
Bucket:
Bore - 1.75"
Stroke - 13.75"
Retracted - 28"
Pin - 0.75"
Rod - 1.125"
   / JD 70a bucket and boom hydraulic cylinder specs #4
Maybe he got a deal on a loader with missing cylinders and is looking for non JD replacements? He wanted a LOT of info!
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
