JD 7000 Series Planter Questions
   / JD 7000 Series Planter Questions #1
derekuk101
KY
M5-111, M8540, M4900, Ford 3600
So we just purchased a 6 row narrow 7000 corn planter. We have a 7000 4 row wide and we thought they were pretty much the same planter. I've discovered that they have different sprockets for the population settings. Basically the 6 row has fewer teeth with a longer chain and the 4 row has more teeth and uses a shorter chain. I can't seen to find the setting chart for the 6 row but I'm guessing that I can just divide the setting in half from the the chart that I have from our 4 row wide planter?? I've done a little research and I think the 6 row is an older planter (conservation) and they switched to the sprockets with more teeth later on. Any help would be appreciated and if you have the chart for the population settings with the fewer teeth could you please post?
Thank you,
   / JD 7000 Series Planter Questions #2
There should be many different sized sprockets to slide around on the shafts to achieve desired spacing ?
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
2016 Sooner STC 9042 LQ Tri-Axle Horse Trailer (A49461)
2016 Sooner STC...
2018 INTERNATIONAL LT625 SLEEPER (A51219)
2018 INTERNATIONAL...
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
