JD 7000 Series Planter Questions
   / JD 7000 Series Planter Questions #1
derekuk101
Bronze Member
KY
M5-111, M8540, M4900, Ford 3600
So we just purchased a 6 row narrow 7000 corn planter. We have a 7000 4 row wide and we thought they were pretty much the same planter. I've discovered that they have different sprockets for the population settings. Basically the 6 row has fewer teeth with a longer chain and the 4 row has more teeth and uses a shorter chain. I can't seen to find the setting chart for the 6 row but I'm guessing that I can just divide the setting in half from the the chart that I have from our 4 row wide planter?? I've done a little research and I think the 6 row is an older planter (conservation) and they switched to the sprockets with more teeth later on. Any help would be appreciated and if you have the chart for the population settings with the fewer teeth could you please post?
Thank you,
   / JD 7000 Series Planter Questions #2
There should be many different sized sprockets to slide around on the shafts to achieve desired spacing ?
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
