Backhoe JD #7 Backhoe - swing cylinder rebuilding - how to dismantle?
   / JD #7 Backhoe - swing cylinder rebuilding - how to dismantle? #21
Earlier last spring was when my second swing cylinder went, first one was year before. Both where complete redos cylinders so rusty couldnt be brought back. Two separate hydraulic shops did each cylinder for me. Asked parts guy in Easton, NY as to why swing cylinder is another 100 more this year than last, "quote" "as parts get older and not ordered as frequently the price goes up according. .... swing cylinders from deere for a #7 approaching $625.00 after tax, for one not two... I guess that's just the way it is...
   / JD #7 Backhoe - swing cylinder rebuilding - how to dismantle? #22
Maybe retrofitting some Surplus Center cylinders would be an option... vs $625 for new Deere.
   / JD #7 Backhoe - swing cylinder rebuilding - how to dismantle? #23
I've looked at cylinders at Surplus Center for my Blackhawk backhoe as my swing cylinders are pretty beat. They don't have anything near the length I need
   / JD #7 Backhoe - swing cylinder rebuilding - how to dismantle? #24
What are the specs that you need?
   / JD #7 Backhoe - swing cylinder rebuilding - how to dismantle? #25
I don't remember offhand. They're a 2" cylinder but the length's I found were either too long or short, by enough that I felt certain I'd have issues.
I'll revisit down the road when the current ones fail or my budget is more robust.
Is it possible to buy just a piston and cut the rod to length?
   / JD #7 Backhoe - swing cylinder rebuilding - how to dismantle? #26
Kinda what I had in mind.
I've bought the "too long" ones and cut both the rod and the cylinder to the right length.
With a machine lathe, the cuts can be made and the cylinder welded back together the right length. Saved big bucks on a rebuild of a skidsteer.
Was just a thought.
   / JD #7 Backhoe - swing cylinder rebuilding - how to dismantle? #27
I don't own a lathe.
Still... the idea opens possibilities. I'll keep it in mind. :D
TPM 10 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
TPM 10 Piece Mini...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2025 JMR Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A56857)
2025 JMR Single...
2015 Yale 5K Forklift (A56435)
2015 Yale 5K...
2024 John Deere 331G Skid Steer w/ WARRANTY! (A59213)
2024 John Deere...
