JD #7 backhoe for a new 790 vs aftermarket models
   / JD #7 backhoe for a new 790 vs aftermarket models #1
gordon21
Lake Lure NC
JD 790
Assuming I am willing to spend $5-6K for a new backhoe, would you guys go for the JD #7 or an aftermarket model. From what I have read, I will NOT go with a 3pt model and spend the extra $ for one with a solid frame assembly. If you recommend another brand, please suggest exact model numbers for my new 790.
   / JD #7 backhoe for a new 790 vs aftermarket models #2
I would get the John Deere. Why? Having a match would be important to me. After all, if they are good enough to make the tractor, then the attachments will probably be good too.
   / JD #7 backhoe for a new 790 vs aftermarket models #3
I have a 7 hoe on my 790 and it is certainly a slick set up. Granted, it's not the biggest, or most powerful thing on the market but it's very well suited to the 790's capabilities. The put on/take off is very fast (under 10 minutes for sure).
I've never seen a different backhoe on a 790 but I'd want some assurance that it goes on and comes off as easily /forums/images/graemlins/smile.gif
   / JD #7 backhoe for a new 790 vs aftermarket models #4
Actually the JD 7 Backhoe retails for $7000 with a 13" bucket, plus installation. The 7 Backhoe is good hoe. You also may want to look at one of the new Woods Groundbreaker-X Backhoes. The BH70-X the unit that would fit your 790. That rig retails for about $7250 or so (with subframe). But no matter what hoe you go with you'll need rear hydroulic kit. Deere calls it a Power Beyond Kit. Thats another $400 - $500 or so.
   / JD #7 backhoe for a new 790 vs aftermarket models #5
Maybe the hydraulic package you mentioned for $400-500 depends on dealer. I'm looking at a quote sheet that was worked up for me today. Mountings, Hydraulics, Subframe and Rear Hanger Brackets for 7 backhoe, $0.00. So if everyone else is charging $500, these guys must be VERY fair. /forums/images/graemlins/grin.gif
   / JD #7 backhoe for a new 790 vs aftermarket models #6
I put the power beyond kit for my backhoe on myself and it was nowhere near $400. Maybe $120? Wasn't too hard to install, if you do it yourself let me know. There was one confusing instruction that I figured out on my own /forums/images/graemlins/smile.gif
   / JD #7 backhoe for a new 790 vs aftermarket models #7
Regarding these power beyond kits from JD. You may
be able to buy just the pwr byd plug and use standard
hoses and adapters. That is how I did 3 of my JD 955s.
The plug was $2.50. I prefer rubber hoses to the steel
pipes and Parker or Pioneer QDs are WAY cheaper than JD
quick disconnects. Deleting the QD bracket also keeps it
from intefering a backhoe seat.
My $.02.
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2013 Nissan Titan Ext. Cab Pickup Truck (A51692)
2013 Nissan Titan...
CONTAINMENT SKID MOUNTED (A53843)
CONTAINMENT SKID...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A53473)
2020 Massey...
