JD #7 backhoe for a new 790 vs aftermarket models
   / JD #7 backhoe for a new 790 vs aftermarket models #1
gordon21
Veteran Member
Lake Lure NC
JD 790
Assuming I am willing to spend $5-6K for a new backhoe, would you guys go for the JD #7 or an aftermarket model. From what I have read, I will NOT go with a 3pt model and spend the extra $ for one with a solid frame assembly. If you recommend another brand, please suggest exact model numbers for my new 790.
   / JD #7 backhoe for a new 790 vs aftermarket models #2
I would get the John Deere. Why? Having a match would be important to me. After all, if they are good enough to make the tractor, then the attachments will probably be good too.
   / JD #7 backhoe for a new 790 vs aftermarket models #3
I have a 7 hoe on my 790 and it is certainly a slick set up. Granted, it's not the biggest, or most powerful thing on the market but it's very well suited to the 790's capabilities. The put on/take off is very fast (under 10 minutes for sure).
I've never seen a different backhoe on a 790 but I'd want some assurance that it goes on and comes off as easily /forums/images/graemlins/smile.gif
   / JD #7 backhoe for a new 790 vs aftermarket models #4
Actually the JD 7 Backhoe retails for $7000 with a 13" bucket, plus installation. The 7 Backhoe is good hoe. You also may want to look at one of the new Woods Groundbreaker-X Backhoes. The BH70-X the unit that would fit your 790. That rig retails for about $7250 or so (with subframe). But no matter what hoe you go with you'll need rear hydroulic kit. Deere calls it a Power Beyond Kit. Thats another $400 - $500 or so.
   / JD #7 backhoe for a new 790 vs aftermarket models #5
Maybe the hydraulic package you mentioned for $400-500 depends on dealer. I'm looking at a quote sheet that was worked up for me today. Mountings, Hydraulics, Subframe and Rear Hanger Brackets for 7 backhoe, $0.00. So if everyone else is charging $500, these guys must be VERY fair. /forums/images/graemlins/grin.gif
   / JD #7 backhoe for a new 790 vs aftermarket models #6
I put the power beyond kit for my backhoe on myself and it was nowhere near $400. Maybe $120? Wasn't too hard to install, if you do it yourself let me know. There was one confusing instruction that I figured out on my own /forums/images/graemlins/smile.gif
   / JD #7 backhoe for a new 790 vs aftermarket models #7
Regarding these power beyond kits from JD. You may
be able to buy just the pwr byd plug and use standard
hoses and adapters. That is how I did 3 of my JD 955s.
The plug was $2.50. I prefer rubber hoses to the steel
pipes and Parker or Pioneer QDs are WAY cheaper than JD
quick disconnects. Deleting the QD bracket also keeps it
from intefering a backhoe seat.
My $.02.
2025 CFG Industrial SSECAG-Y (A50123)
2025 CFG...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
