JD 6920s gear box re cal
   / JD 6920s gear box re cal #1
6920s
Leicestershire
John Deere 6920s
Hi guys just wondering if there is an easy in-can way to re calibrate the auto quad transmission on my 69 it's on a 03 plate, somtimes it seems to be abit violent when changing power shifts, especially when in auto.. Cheers!
   / JD 6920s gear box re cal #2
:welcome:
Can you tell us more?
Not sure I understand, maybe others will do better. ;)
Well I know on the claas ares and the new Hollands with the electric clutches and + - buttons to go through the ranges and power shifts you can re calibrate the gear box, on the class you rev it at 1200rpm, hold the 4wd button down, put the reverser shuttle in forward and the computer starts flashing forwards and backwards repeatedly, the tractor doesn't move but the engine does accelerate and decelerate and you can hear and feel its doing stuff in the gearbox, when it's done the claas responds better on the clutch and is smoother through all the gears.. I was wondering if this could be done on the 6920, as it feels like the power shifts are a little violent when changing at times, the way it feels is, if it where on the class, you would re-calibrate the box. Wondering if anyone had any clues. Thanks!
Cheers mate had a good look through but unfortunately can't find anything relevant, will ask the dealer next time I'm in there.
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
RV Hitch (A50121)
RV Hitch (A50121)
2020 CATERPILLAR 299D3XE SKID STEER (A52705)
2020 CATERPILLAR...
10ft Inclosed trailer (A53424)
10ft Inclosed...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
