JD 6920s gear box re cal
   / JD 6920s gear box re cal #1
6920s
Leicestershire
John Deere 6920s
Hi guys just wondering if there is an easy in-can way to re calibrate the auto quad transmission on my 69 it's on a 03 plate, somtimes it seems to be abit violent when changing power shifts, especially when in auto.. Cheers!
   / JD 6920s gear box re cal #2
:welcome:
Can you tell us more?
Not sure I understand, maybe others will do better. ;)
Well I know on the claas ares and the new Hollands with the electric clutches and + - buttons to go through the ranges and power shifts you can re calibrate the gear box, on the class you rev it at 1200rpm, hold the 4wd button down, put the reverser shuttle in forward and the computer starts flashing forwards and backwards repeatedly, the tractor doesn't move but the engine does accelerate and decelerate and you can hear and feel its doing stuff in the gearbox, when it's done the claas responds better on the clutch and is smoother through all the gears.. I was wondering if this could be done on the 6920, as it feels like the power shifts are a little violent when changing at times, the way it feels is, if it where on the class, you would re-calibrate the box. Wondering if anyone had any clues. Thanks!
Cheers mate had a good look through but unfortunately can't find anything relevant, will ask the dealer next time I'm in there.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
Killbros 260 Seed Conveyor (A55301)
Killbros 260 Seed...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A55218)
2023 Maxx-D TDX...
1988 Kenworth W900B Dump Truck with 3406B CAT (A55218)
1988 Kenworth...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
