JD 670 pto problems
   / JD 670 pto problems #1
lorrain420
John Deere 670
I am new to this site i figured it would be a place to get some help. While snowblowing with my tractor i uncovered a blanket which was sucked into the snowblower. when i saw the blanket i immedietly pushed in the clutch so i wouldnt damage anything. after getting the blanket out of the snowblower i discovered when i engage my pto absolutely nothing happens. it seems i might have broken something inside the tractor. if anyone has suggestions on what i may have broke and what to start taking apart it would be greatly appreciated.
   / JD 670 pto problems #2
:welcome:
And you are sure it isn't just a shear pin that did its job?
   / JD 670 pto problems #3
I think it's the blower's shear pin too.
Suggest you unhook the blower and engage the PTO to see if it turns. Then hook another implement up to see it the PTO functions as it should.
While you have the blower off, take a look at it's shear pin.
Those 670's are tough little tractors...I doubt you did it any harm.
2006-2009 Ford 4x4 Pickup Truck Bed (A49461)
2006-2009 Ford 4x4...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
John Deere 270 Wheeled Skid Steer (A50322)
John Deere 270...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
2015 F-550 Bucket Truck Gas Engine (A51039)
2015 F-550 Bucket...
