Oil & Fuel JD 670 - oil fill - diff oil check
   / JD 670 - oil fill - diff oil check #1
Reg312
Missouri
JD 322 - AC 712 && 912 - Snapper ZTR
Getting my New to me John deere 670 compact (FEL - PS - 4x4) ready for winter and ran into 3, what might be classified as stupid questions - but here goes.
1. After draining oil I filled at top of valve cover. BUT there is also an oil fill on the right side of engine by lower radiator hose and just right of the fuel pump. Whats that oil fill for ??????
2. Rear Diff. - I can't find where to check the oil level in it like the front diff. OR does the oil that runs the PS and FEL also lube the Rear diff??? If not - where/how do I check oil level in rear diff.
3. how about the Transmission - or does that too run of the FEL oil?
My limited manual doesn't say. ---- thanks
   / JD 670 - oil fill - diff oil check #2
engine was used for more than one application, so both oil fills will work
rearend/tranny/diff & loader work on the oil in the rear housing, dipstick is in the very back on the pto shaft plate RH side
Thats what i figured. So I'm good to go. Thanks.
   / JD 670 - oil fill - diff oil check #4
Nice little tractor, the 670! My first tractor was a 670...sometimes I wish I'd kept it!
Anyway, you can buy the service manual on CD-ROM from Deere. It was about $50 when I bought mine.
   / JD 670 - oil fill - diff oil check #5
It was my first tractor also. Loved it. Had it for 8 trouble free years. Also wish I would have kept it.
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
1274 (A50490)
1274 (A50490)
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A51222)
LINK BELT LB-98...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
J and L Cargo Express Shadowmaster Enclosed Trailer (A51039)
J and L Cargo...
