3-Point Hitch JD 670 comact tractor 3pt question
   / JD 670 comact tractor 3pt question #1
cartod
Platinum Member
Northern, West Virginia
JD 4066, 1023
I have a 95 670 with a MMM. Is there anyway to lock the mowing deck up so that I can use the grader blade without dragging the deck? thanks..
   / JD 670 comact tractor 3pt question #2
My 4110 has a optional "lock up" kit that will hold the deck up...I assume you could make on for your machine. There are some pictures that I posted in THIS thread.
   / JD 670 comact tractor 3pt question #3
Just had to say that is one GREAT looking JD 670 tractor! Looks like it just came off the showroom floor! Just curious but are you the original owner?
   / JD 670 comact tractor 3pt question #4
With the mower deck lifted all the way up, can you just turn the mow height adjustment all the way up? That would normally keep the deck from dropping when lowered. Or does that feature not exist without the SCV hydraulics?
Hey thanks, I bought it off my neighbor at 412 hours. It now has 485 hrs and never seen the rain.
No, the height adjustment is on the 3 pt. hitch lever.
NEW Woods 6ft Finish Mower (A55315)
NEW Woods 6ft...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55315)
2025 Wacker Neuson...
