JD 6506
   / JD 6506 #1
Graham1959
Sarina, Qld. Australia
247 b
If I don't start this tractor for a couple of weeks It won't start and it is hard to get it to prime it only has 4000hrs and has plenty of power and no smoke once it is going and has no problem starting unless it is not used for a four or five days
   / JD 6506 #2
Sounds as if you need to install a fuel line check valve to stop fuel from bleeding back to tank from filter.
   / JD 6506
I have installed a small sprung loaded check which was new but it could be faulty, this did help but was just wondering why it would be bleeding back design fault?
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
DOOSAN G25KW GENERATOR (A53843)
DOOSAN G25KW...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A54607)
2014 HINO 338 26FT...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
