JD 650 Battery Polarity Issue
Status
Not open for further replies.
   / JD 650 Battery Polarity Issue #61
Could please list some of these later model machines that have 12V positive ground battery connections???? Thanks,Jim
Although NOT that 'later model', my 1961 Morris Oxford was Positive ground as was my 1955 Packard. Both of them 12 volt systems.
You're correct I wouldn't consider your 1961 Morris Oxford or '55 Packard late models by any stretch of the imagination!!!!!!!!!!!
   / JD 650 Battery Polarity Issue #62
My charger has auto polarity correction, maybe you need a better charger.
   / JD 650 Battery Polarity Issue #63
White IS the make.. I simply don't have the model tucked into my pocket.
   / JD 650 Battery Polarity Issue #64
The military humvee has a 24v negative ground system AND an isolated 12V system (uses one of the pair of 12v batteries hooked in series to make 24V)
Looks like a 1973 Mack semi truck was available as positive ground: 12V positive ground? - IH Trucks - Red Power Magazine Community
Also, the Cat 955 Traxcavator (made in the 50s-60s and possibly into the 70s) had some models which were positive ground.
Aaron Z
   / JD 650 Battery Polarity Issue #65
Whoopie. I've had the Snap-On charger for 28 years and it still works exactly as designed and has always done it's job flawlessly. Doubt I need a 'new one'.
So a White BRAND truck, not a "white truck," as you stated originally. Got it.
   / JD 650 Battery Polarity Issue #66
Snap on is Junk, Old tech.
   / JD 650 Battery Polarity Issue #67
Junk with a capital J, eh?! According to you, perhaps, I'm fairly sure there isn't a garage or decent mechanic or planet Earth that values YOUR opinion.
   / JD 650 Battery Polarity Issue #68
So EVERY would cover both. Huh?!
Using the word 'every' makes it sounds as if the standard has to undergo extensive modification to cover 'every oddball or antiquated grounding possibility' which is clearly false and misleading.
   / JD 650 Battery Polarity Issue #69
All the Top Techs call me and ask MY opinion on tools!!
   / JD 650 Battery Polarity Issue #70
Status
SCALES & PEA (A58374)
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
Adams 6T (A56435)
Adams 6T (A56435)
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
