JD 6410 Power Reverser Problems/Won't Move
/ JD 6410 Power Reverser Problems/Won't Move #1
CMCattle
Texas
JD 6410
Only a couple of hours after purchasing my 6410 and running it in the hay field, my left hand reverser switched kicked into neutral and then had a constant "beep" while in gear and running. From then on the tractor would start beeping after 30-45 minuets of running. The tractor was running fine, but I was trying to solve the "beeping" issue because it was about to drive me crazy! I changed the pressure sensor, both hydraulic filters and transmission filter to begin with because that's where someone told me to start at. That didn't solve anything. Several weeks later, tractor still beeping, decided to try and replace the enable pressure switch. After changing it, the tractor will not go forward or backwards, but still beeps when we put it in gear. I'm not getting any fire to the foward or reverse solenoids. The enable solenoid seems to be engaged all the time. I've checked all 4 relays in fuse panel and they check to be good. Even bought a new relay to move t each location to verify. Also checked park break switch and it's still beeping. If ANYBODY has any suggestions, I would greatly appreciate it.
/ JD 6410 Power Reverser Problems/Won't Move #2
Hate to say it but it might be cheaper to have the dealer hook it up to the computer and see what codes it's throwing. Save money by not throwing anymore parts at it. These problems are frustrating to say the least
Brett
No codes are showing on tractor now.. Tried the fuse code strategy, but it isn't throwing the ECU code like they said it should.
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2012 EAST 30' DUMP TRAILER (A64277)
2012 EAST 30' DUMP...
GHT Series Hopper Tank 75T Grain Bin (A65579)
GHT Series Hopper...
2022 EZ-GO ELITE...
Trench Box (A64553)
Trench Box (A64553)
2014 CASE CX160C EXCAVATOR (A65053)
2014 CASE CX160C...
