JD 6220 Transmission issue
   / JD 6220 Transmission issue #1
BBOB57
Chandler, Oklahoma
JD 6220
Greetings,
I have a low hour 6220 with a left had reverser. The last time I used it, it would jump to neutral on the reverser and the tach would quit. Also, I got three flashing warning light on the dash. This happened after about 1 hour of use. I can shut the tractor off for 5 -15 min. and it will work for a while. I looked at the solenoids on the transmission, and the one on the opposite side from the FNR solenoids (#27 on the diagrams I have seen on this forum) appears to have hydraulic fluid in the connector. Can anyone tell me what this solenoid does and can it cause this problem?
Thanks,
   / JD 6220 Transmission issue #2
If oil gets into these switches , it can upset the signal . Oil in your plug is a tell tail the switch is faulty . They have a seal on the detent shaft that is supposed to keep the oil out of the switch but they fail .
The top switch on my New Holland is faulty , if I go on a steep angle to the left , the oil gets into the switch and the shift is erratic for a few hours . I haven't had time to pull it out and order a new one .
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
2010 KMC 3376 Peanut Combine (A53473)
2010 KMC 3376...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
