JD 6215 vs NH TD5050
   / JD 6215 vs NH TD5050 #1
arl242
Tipton, MO
NH TD 5050
I am in the market for a different utility tractor. I am considering a New Holland TD5050 or a JD 6215 MFWD. There seems to be quite a few 5050's on the market but no one can tell me why. Some have low hours, less than 1,000. The 6215 has over 4,600 hrs. Should I be concerned with the higher hrs on the JD? Does anyone have information about the TD5050? I realize the NH is a little bigger HP, but either tractor should be fine for my operation.
   / JD 6215 vs NH TD5050 #2
The TD is the "cheap" built in Turkey tractor, same as the CIH JX / Farmall series. Old Fiat design. Gear drive, dry clutch and synchro shuttle. Think 6215 is economy version of 6220, likely 16F/16R power quad / LH shuttle
No experience operating either.
   / JD 6215 vs NH TD5050 #3
From what I see on Tractordata.com the power is splitting hairs, both have 80pto hp. The 6215 has fully synchronized transmissions where the NH TD5050 has partially synchronized transmissions.
I don't have experience with either one but will be watching this thread with interest.
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
2014 MACK CXU613 (A50854)
2014 MACK CXU613...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A49461)
2008 Ford F-450...
