JD 6210 Three Point Hitch slow
   / JD 6210 Three Point Hitch slow #1
VE1967
Tupelo, MS
JD 6210
I have an open station 1999 JD 6210 with a 640 FEL. The FEL operates normally as well as the cylinders on my grader blade. The three point hitch raises normally (when using the "up" button). However, it is very slow and unresponsive when I try to lower or make height adjustments to a 3 pt implement (even a fairly heavy grader blade).
Any help would be appreciated.
Thanks
   / JD 6210 Three Point Hitch slow #2
You know there is the speed control pot under the little flip up cover? Does it work?
Two pots. One controls speed (can't remember if it's up and down or just down) and the other controls maximum height.
Not sure about the draft control knob. Never did figure that one out. Just turn it off CCW until it clicks.
Yes. I had checked that and the speed control pot was set to the highest setting. I will double check just to make sure.
Thanks.
   / JD 6210 Three Point Hitch slow #4
Try it the other direction. Maybe the pot is bad. Sometimes just working a pot back and forth will restore operation. If not, some good zero-residue cleaner might help if you can get at the wiper inside. Sometimes if a pot is sealed, you can drill a tiny hole to spray in the cleaner. JD probalby wants enough money for a new pot.
   / JD 6210 Three Point Hitch slow #5
I agree. Crank that thing around... I bet it will clear up.
I'll give it a try.
Thanks.
I shoulda thought of that!!
As you might have already guessed, that worked.
I am very grateful for the advice and more than a little embarrassed.
Thanks again.
   / JD 6210 Three Point Hitch slow #8
I shoulda thought of that!! As you might have already guessed, that worked. I am very grateful for the advice and more than a little embarrassed. Thanks again.
Great news!
Hey, lose the embarrassment! It happens. I once looked for my sunglasses for a half hour while they were on the bill of my cap. Anyone who says they don't do something dumb is lying.
Sent from my iPad using TractorByNet
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2022 DRAGON...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
7033 (A51691)
7033 (A51691)
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51691)
2013 Mitsubishi...
